RE: O.S. LA 15 carb problems
If the little spray bar extention is damaged, no problem. I've put a short piece of metal tubing into the throttle housing "as is" and it works fine. I use regular brass fuel line from the scrap after fitting tanks. I bring the tube just to the edge of the venturi and fix it in place with JB Weld.
