RCU Forums - View Single Post - decathalon engine mounting
Old 08-12-2009 | 03:35 PM
billd76's Avatar
billd76
Default RE: decathalon engine mounting
Brett,
Just got the servo rods implaced at lunch time today. One wire, one servo for the extention (reverse on the Tx for the elevator). One servo for each aileron with a y connector to the Rx. Rudder same as elevator. All thats left is to install the battery switch, fuel tank and wing struts. mounting plates for the wing struts are screwed in place. Shouild be ready to run a tank of fuel through it later tonight. Will be careful about the stalls. What engine did you use? prop size? At the moment I'm going with an 11 x 6 prop. Looks terribly small on this model.
