RCU Forums - View Single Post - CARBURETORS, BERNOULLI, AIR COMPRESSION, LEAN OR RICH????
Old 08-12-2009 | 03:38 PM
combatpigg's Avatar
combatpigg
Default RE: CARBURETORS, BERNOULLI, AIR COMPRESSION, LEAN OR RICH????
Manifold pressure [vacuum] decreases with demand. The spring loaded metering rods are held in the lean position by high manifold pressure when demand is low. The main jets are enabled when the manifold pressure is low, then this circuit is allowed to flow as much fuel as the venturi can siphon from it.
