RCU Forums - View Single Post - Proud Bird Construction Thread
Old 08-12-2009 | 08:11 PM
  #93
sahartman21
Default RE: Proud Bird Construction Thread
The finish is smooth but it is not perfect.
You get a smoother finish using the peel ply in the bag than if you just applied the finishing epoxy with a squeegee alone.
The surface is only as smooth as the peel ply and bag. I ironed the peel ply so there were no wrinkles.
The following picture shows what the wing looks like after some sanding.
The hinge made of 2 ounce glass is smoother than the one done with taffeta. We will see what holds up better.
