RCU Forums - View Single Post - Cobra Avenger/ Rebuild
Old 08-12-2009 | 11:19 PM
unclecrash's Avatar
unclecrash
Default Cobra Avenger/ Rebuild
Well Mike you got my wheels spinning. After Mike/AKA Toyota Truckin sent me a PM the other day and a friend stopped by a day later and wanted to see my boats run. I decided to start on the 90 size avenger first. Will take some time funds are always lacking. Need 1/4 scale servo,reciever,90 size pipe, and a couple servos for the 3rd channel and throttle. I might use the 2 HS 425 hitec I have for the. I need to redo all linkage and need 4 rubber isolators to mount the engine. Im going to leave it in the Tony the tiger colors. So It will take less time and money. Here is most of the hardware polished up and ready to go on the hull but I need the isolators for the engine. And will clean up the hull. I had to cut out part of the right front sponson because it had 3 broken off bolts that I couldn't get out so I added some hard wood and will use some wood screws to reattach the turn fin that I swipped off the other rigger.
ID:	1255258   Click image for larger version
