RE: weight VS stability
none of the wheels have sticky points, the control throws were left at factory default i did not tamper with them, and i never input full throws anyways, i try to do gentle liftoffs and elegant turns, im not really into aggressive flying.
Now that i look at the plane more closely, i notice that the control throws are currently in their lowest position, and ailerons are not adjustable at all. The only way i can adjust throws is by changing the position of the push rod on the control surface, and i cant make the throws less than what they already are.
Unfortunately i don't have a local baseball diamond, and all of the nearby parking lots and paved areas are riddled with lamp posts and other tall fixtures that i am reluctant to fly around.
I will give the corsair another try, after i actually get it balanced.
