ORIGINAL: tlange88
ok, i finally took the motor off, it ended up being the flywheel where the clutch pins go in were broke, and the C clip holding the clutches was broke, plus there was no spring around the clutch.. so i got a new flywheel, clutch shoes and spring, clutch bell housing coming. i also ordered a new body, tuned pipe, fuel filter, and one of the gears ( can't remember which one). my last question is, the tuned pipe i ordered from rctoysnh.com for like 18 bucks does it come with the header? if not... which i hope it does! will that improve the performance at all with the factory header?
thanks again, Travis</p>
Do not know who you are or what your order was, but,
The tuned metal muffler is part number 02124 = 15.60
It attaches to the stock coupler.
The header manifold is 02131a=4.99
PM us if you need more help.
If you need a manual which shows blow ups and part numbers let us know via pm or email we can email one to you.
