OS FX.46 performance
That little screw on top is the throttle stop screw... leave it as it is.
the low speed needle is in the throttle arm ......... screw in to lean the idle mixture . and out to richen the idle mixture.
i would put a 11*5 for better thrust .
( a 12*5 will be too much prop and lower the revs )
