RE: Setup Question - AMPS seem high
Jeff,
Great information, thanks! I switched the prop to an APC 10x7e and here are the readings at full throttle: 10.85v, 41.7A, and 450W. Looks like I will be using the 10x7 as it is under the motor max amps and esc max continuous, even though it is close to the border line...I will just have to keep this in mind while flying. I will also be getting about 95W per pound, so still pretty good.
Test flight is tomorrow, so hope all goes well!
Until then,
Pat
