RCU Forums - View Single Post - CMP Zero Makeover
Old 08-13-2009 | 07:58 PM
  #201
ZERO-322
Default RE: CMP Zero Makeover
I don't have this Zero , but I do have the 120 size 71" wing span and yes its used as kinda of shim to get the engine mounted forward enough to match the planed spec sometimes you will need it sometimes you won't depending on the engine you are using , turned out I it needed and used it
