RCU Forums - View Single Post - Setup Question - AMPS seem high
Old 08-13-2009 | 08:02 PM
TedMo
Default RE: Setup Question - AMPS seem high
I think you are doing the right thing testing with different props. One thing I don't see specified by you is the c rating of bat. that is also a n important factor. One more thing is the static tests will likely be higher than when in the air where it can unload. You should do fine.
