RCU Forums - View Single Post - Engine problems
Old 08-14-2009 | 02:35 PM
mikewait
Default RE: Engine problems
I figured it out!!!
I got it to run but once it ran for like 5 minutes i would encounter the problem it was like a 1/4 throttle run away that i could steer but not stop... and if i braked it would not stop it because the break i adjusted them really weak.
It's probably and air leak right??? because after i shut it down i heard a hissing noise. It sounded similar to wind blowing on a fire. that is probably hot air leaking out right??
If so how do i fix it?
