Pipe: Macs Tuned Pipe No. 1328 (trimmed 2 3/8")
Pressure Fitting: Prather No. 9005
Flywheel: Shockwave 36 No. PRB2057
Flex Coupling (collet): Aeromarine No. AEM1732 /OS21 X 187
Flex Cable: Prather No. 8020 3/16" x 12" Flex Cable (no need for trimming, clean up end)
Drive Dog: Aeromarine AEM1510 3/16"
Prop: Octura M445
Tail Nut: Octura OC6PNMM
Turn Fin: Aquacraft AQUB9539 (UL-1 Black Fin), need to elongate the bracket holes to fit
other mods:
- Engine Mounts (use MVD stock rubber bushings and inserts)
- Tuned pipe will prohibit the used of the Grim cowl lockes..toss them..they are junk.. fab new locks with hook and O-ring
- Set rudder back at least 3/4".. I used square aluminum tubing
- Control box.. (same setup as cowl locks, used picture frame hangers)
Here ya go:
After first WOT run without spinning:
RUDDER EXTENSION:
COWL LOCKS
BOX LOCKS
