RCU Forums - View Single Post - Pull pull help needed
Old 08-15-2009 | 11:20 PM
bgold
Default RE: Pull pull help needed
What will keep your cables tighter than any thing is to have the pivot point of the control horn connection right on the hinge line and then use a servo arm that will have exactly the same width as the rudder horns. I cross or don't depending on the angle I need to get on the cables so they don't rub the fuselage at entry point.
