RCU Forums - View Single Post - Saito .82 Quits when idle
Old 08-16-2009 | 01:34 PM
FILE IFR 's Avatar
FILE IFR
Default RE: Saito .82 Quits when idle
ORIGINAL: obriendigital
I have set the low end needle back to factory settings, nearly flush with the throttle arm, then moved out a quarter turn at a time.
A 1/4 turn in or out is way too much! You'll almost never get it adjusting that much each time.
1/8 turn is a bit much, I'd go less.. like the screwdriver's slot blade width.
Some people do not realize just how sensitive these adjustments are, so adjust in much smaller increments.
