RCU Forums - View Single Post - axe cp thread
Old 08-16-2009 | 11:10 PM
  #1954
PilotLight's Avatar
PilotLight
Default RE: axe cp thread
ORIGINAL: PilotLight
Its held on by sleeve retainer (glue). It just slides back off once the glue releases its grip. I used a pully puller to remove mine available at hobby stores. Other ways are to support the pinion and push the shaft through it (any technique you can come up with), or to heat the pinion and then gently pull it off with pliers.
