RE: Prop location at compression
the best way to start a engine with a magnito is to set the start of the compression stroke (prop) at 12:00. then start your flip at 3:00. if u try to flip a magnito right on compression you will just keep getting a pop. if u do as above u get full spark then bang!!!
