soldering antenna wire?
When I was cleaning my plane after flying this w/e, about 6" of the antenna wire broke off where it exits the plane. I did a range check with the piece off and only got about 35 paces before the servos started chattering. Can I solder the piece back on and get my range back where it should be, or do I have to send it back to futaba to have a whole new antenna put on? Thank you
