RCU Forums - View Single Post - Hog Bipe Should I Lighten Control Surfaces?
Old 08-17-2009 | 08:32 AM
av8djc
Default RE: Hog Bipe Should I Lighten Control Surfaces?
Ailerons are small and near enough to the CG to be fine as is. They might actually be better on the heavy side to resist twisting in flight. Tail feathers your choice but do not get carried away if you decide to put some holes in them. I'd rather see you build some new ones out of stick stock. But that said I agree with Brian, it will be fine as is.
