First flight Help Please!!!!!!!
<span style="font-size: larger">OK guy's i went with the Honeybee 004, I opened it up tightened all the screw charged the battery and took it into the Dinning room to take it for my first flight. When it throttled up the tail Started Spinning clock wise and the more throttle i gave it the faster it went around and around. I finally got it to stop spinning and slowly throttle up trying to get it to lift off slowly so it wouldn't take off and slam into a wall. I took the throttle to full throttle and the Heli barely lifted of the ground. I read you have to throttle it pretty fast to get it of the ground and once in the air you could throttle down, when i tried it all that happened was the tail went spinning around and slide across the floor. Any ideals to what I am doing wrong? </span>
