Kyosho GeeBee Z Landing Gear Problem
Both of mine are loose after a less than perfect landing. It appears the block inside the wing that holds the gear from moving forward or back comes loose quite easily. Considering the fact that the belly pan is on the bottom, I think I can do surgery on the top of the wing, and the repair will still fit within the wide fuze.
