RCU Forums - View Single Post - phase porting????
Old 08-18-2009 | 03:01 AM
DarZeelon's Avatar
DarZeelon
Default RE: phase porting????
ORIGINAL: streetrodder
... My .40 is a hot OS.40FX...
DS,
This clause in an oxymoron...
There is no such thing as a 'hot OS.40FX'...
It is just an average power sport engine.
Also, because it has an ABN piston-and-liner set, you cannot successfully port it...
The electro-less nickel coating relies on surface continuity, for its integrity.
If you Dremel the ports, this continuity will be broken and the mediocre bond-strength of the nickel to the brass, will allow the nickel to peel off...
If you do think porting the sleeve is within your scope of possibilities, start with a true-chromium P+L set, such as the one for a Magnum/ASP .40 Pro (made by Sanye in China).
The chromium has a superior bond strength to the brass and will not peel off.
