RE: Saito .82 Quits when idle
Thanks for all of the advice, i tried the move the needle until it won't start...still no luck.
Well, tried a brand new plug, no luck at all. Set it back to the factory low end and it will start, but when i pull the glow it dies. So, if i rev it up to full throttle set the high end with the tach and am getting about 9,000RPM, and pull the plug it runs, but then back the throttle off and it dies about 7,000RPM every time. Tried leaning the low end a bit again, no luck. I am really out of ideas now...
