Thanks for the help guys...I found the right combination of mix and switch but I couldn't tell you how
. I just played with it all evening then it worked. Now I've got "it" on a Harrier and 2 Ucandos..Edge is next.
I reversed the channel 1 and 6 servo connections to get the surfaces moving in the same direction. Doesn't make sense but it helped.
Now I'm wondering if the ailerons shouldn't move opposite to the elevator for 3D maneuvers.
What do you think before I take it up?
