RE: Pull Pull Rudder and Tailwheel on TF P-47
Hi,
you should be able to run two sets of cables from one servo to the rudder and the tail wheel as long as neither has a smaller travel than the servo movement or you may get the servo binding and less than full travel on the other control surface.
