RE: CGRCJets A-10 Build Thread
OK,
I am going to start with something easy and work on the fins/rudders.
First questions:
I can see where I should put the rudder servos but there is no 'hole'. Do I need to cut a servo hatch into the skin?
Is there a block in the rudders for the horn and, if so, where? Is one of the horns in the kit for the rudders?
Did the prototypes have the fins glued to the tailplane or were they bolted on? Was any reinforcement employed at the joint?
