ORIGINAL: beesknees
Thanks for the memory foam offer, Tim, but I think I`ll have this noise problem solved shortly....if I could just get this little beast apart ! lol
Gentlemen, I have the VSTank 1/24th scale late production Tiger, and I cant get the deck off the hull. I`ve removed the 3 screws on both sides that were above the roadwheels and the one screw that was at the front underside of the hull. So thats 7 screws I`ve taken out and this
little beast seems as solidly together as ever. What am I missing ?
Thanks guys !
Barry
Nope, you are not missing anything. 3 screw on the side, one on the front lower hull. Then just pull it hard, they tend to stick. I have 11 Tigers and removed hulls in all of them, trust me, you won't break anything. Just be sure to put it back fully too. And be sure the orange wire from antennae is not jammed when you put it back.
