RE: CGRCJets A-10 Build Thread
If you guys want you can start out with something more simple like the detail on the fuselodge. Their are a few good sights that you can go on, including warthog territory, A10 walkarounds and airliners.net. These are the sights that i have found to be the most useful. Here are a few of my pics of the detail that i put on. There are some square outline detail on fuse. These will be cut out to glue in the vacuum formed avionics cooling vent. The outer vents will just be glued on.
chris
