RE: Pull Pull Rudder and Tailwheel on TF P-47
Thanks bigtim. Those pictures help a lot. I was thinking pull pull for the rudder. I might use the same set up as you only using the pull pull for the rudder with the pushrod for the tailwheel. That would make it easier to use the stock tailwheel.
