RE: 7955 programming
The high resolution mode is limited to standard travel (about 90 degrees) but you can get a little more if you max out the EPA and D/R. If you need more travel at the control surface then you will need to use a larger horn. Changing to low resolution mode defeats the advantage of improved resolution of the 7XXX series servos.
Mike.
