RCU Forums - View Single Post - The name for this tx mix?
Old 08-19-2009 | 04:42 PM
Allfat's Avatar
Allfat
Default RE: The name for this tx mix?
ORIGINAL: expo
Thanks John. I understand if the surfaces moved in opposite directions tighter loops would be possible. I call it ''chasing the tail'' in a tight loop. I don't know for sure but I'm thinking that this mix causing up flaps (ailerons), aka airbrake, along with up elevator would allow hi alpha flight, aka harrier, to be performed with less chance of a wing drop or rocking.
Having a brain fart here. Does this make sense or do I have it backwards?
Maybe now that I've got the programming down I should pose this question in the 3D forum?
If you set it so the ailerons move the same as the elevator, then you will be more stable in a harrier attitude. This is because you are essentially reducing the angle of attack of the wing, so it is less likely to stall off to one side.
