RE: CMP 120 Zero ARF Build thread
Ok Guys I could use a little help , I'm in the process of building a full cockpit for this bird and have found that at least one or two servos would have to be relocated....Full figure pilot won't fit and the cockpit just doesn't look right with the bottom of the servos sticking up that far , two reasons I don't want to do this is I don't want to cut out the servo tray completely and have to do all that work , but the main reason is I know this Zero is going to need some nose weight let alone relocate the servos further back , so the solution I have come up with is to go with a low profile servos for the rudder and elevator , Can anyone suggest a low profile high torque digital servo that would work ? any help would be greatly appreciated
thanks
Mike
