RCU Forums - View Single Post - Thunder Tiger 46 Pro Carb Question
Old 06-27-2003 | 09:11 PM
FlyingPilgrim's Avatar
FlyingPilgrim
My Feedback: (26)
Default Thunder Tiger 46 Pro Carb Question
Yes, the o-ring will be visible after correctly mounting your carb. Simply line up the carb, press down to squish the o-ring a little (just enough to get a good seal), then tighten the draw bar nut. Don't tighten it too hard, it doesn't need to be torqued really hard, and you don't want to strip the threads or distort the carb throat.
FP
