RCU Forums - View Single Post - Yep, another beginner build question...
Old 08-20-2009 | 09:25 PM
  #43
TinmanJones
Default RE: Yep, another beginner build question...
ORIGINAL: GaryHarris
ORIGINAL: TinmanJones
Sorry for posting so much, but I just thought of a couple more things while looking my 4* over. Besides, I'm getting bored looking out the window waiting for the UPS guy. [X(] I have a Big Stik 40 coming today.
The filler I used insted of balsa filler is called ''Patch-n-Paint'' lightweight spackling.
I had some problems using the standard push rods. I would highly recommend building the entire plane, including the electronics before covering it. I had binding pushrod issues and wished I hadn't covered the plane yet. I also had to add more lead in the nose than maybe I should have if the plane wasn't covered yet. I read here and I think it was RCKen who builds planes in this way and I now see it as gospel. Build the entire plane and balance it before covering. Make sure everything is nice and smooth with the pushrods.
The 4* is known to build tail heavy. With a Saito 100, I still had to add about a pound of lead and epoxy up front to get the planes CG right. If I could of balanced the plane before covering, I might of saved a few dead weight ounces of lead and as it stands now, Ill never be able to remove the tank or the battery pack without tearing the plane apart. My plane comes in at 8 1/2 pounds but still floats like a butterfly, ans stings like a bee when the throttle is applied!
As heavy as it came out, I used a CG landing gear up front and a Sullivan tail wheel set up. I had alot of bounce and was knicking 15'' props. The CG landing gear fixed that.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHBP8&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXFV46&P=0
I had some issues with the rear end set up. The spring was too soft to turn the plane maybe cause it was so heavy, I dunno. I bent a t-pin in half and punched it in real close to the spring part, punched some holes in the covering along the long wire part and CAed the long wire part down to the underside of the rudder. Pretty much eliminating everything but the coil spring part.
Gary... please no apologies, please... LOL
everything ive read on the forums say to NOT use the original landing gear or tail wheel... those are things ill replace for sure, when i get to that point in the build...
i appreciate the links...
when you say to build the entire airplane, including the electronics, you mean to actually install every single part of the airplane and have it just like i would when i get ready to fly it the very first time, MINUS the covering, correct??? and balance it at that point???
ive chatted with RCKen some over the last couple of days... i look forward to his help throughout the build as well... ive followed him pretty close in some other build threads and think alot of the way he does things...
I wish I would installed all of the electronics and did the balancing act before I covered my plane. Ken is da man as well as Mike. For covering a plane, check this out.
http://www.rcuniverse.com/forum/m_4385133/tm.htm
thanks for the coving link... ill be sure to watch em as i move toward that part of the build...
tonight while i was cleaning up my shop, gettin ready to move my work bench in, i ran across some OLD, and i mean OOLLDDD, Z-Poxy (epoxy) 30 minute... im not sure how old, im guessing probably 8-9yrs... that stuff probably needs to be trashed, right? surely it isnt any good after that long...
