ORIGINAL: websterphreaky
It also weighs a ton comparatively. I'd like to see you use that in any Multiplex model or a 25 - 40 size 3D plane without making worthless as a 3D plane.
The point in using a micro camera is NOT changing the flight characteristics of the model.
It seems with the complaints on here that quality is a issue. I used this camera on the inside of a 40 size j-3 cub and it flew better than without it! I balanced the CG all the same. I also put it on a 40 size low wing sport plane, it flew fine. The camera is only 3.5oz. If you don't have 3.5 oz of thrust to spare on a 40 3D plane, its not much of a 3D plane at all. If you want a quality picture HD is the way to go. At 3.5oz, if you keep your CG the same, you should not notice much change if any. Then again, if you don't care about quality and will settle for 640x480, tape your cell phone to the plane and put it on video.
