RCU Forums - View Single Post - Carb leaking fuel
Old 08-21-2009 | 07:13 AM
Seb23's Avatar
Seb23
Default RE: Carb leaking fuel
yeah well after priming, i release the choke leaver and the fuel i has primed kind of all fall's out ... im sure some goes in the intake because when i do the compression exercise all is fine, what was happening is fuel was being siphoned into the carb, therefore leaking out automatically, i was sure fuel had to be higher than the carb
I will try again today and let you know of the results
