RCU Forums - View Single Post - This Citabria doesn't want to roll!!?!
Old 08-21-2009 | 09:06 AM
  #35
da Rock
Default RE: This Citabria doesn't want to roll!!?!
Adverse yaw has a simple cause.
One wing has more drag than the other.
Moreover, with cambered wings, the up-going aileron momentarily reduces the drag on that side. In reality, one wing has less drag than the other.
In fact, in order to get "full power" from ailerons on cambered wings, if you want the most power from the combination of both ailerons, the ailerons must move at different rates. Full scale airliners have been making more efficient turns for years by using spoilers. Or more correctly, they've been doing single spoiler turns. The spoiler on the wing that'll be inside the turn comes up, and that's it. The wing gets a bit of drag, a little less lift, and the sucker banks a bit and yaws a tad, and less fuel is burned while it makes the desired turn. You wanted to turn, and by golly you ain't going to change directions without changine directions and they all gotta yaw to do that.
Adverse yaw has a simple cause; the wrong wing has more drag than the other.
