RCU Forums - View Single Post - How to remove stripped engine mounting bolts?
Old 08-21-2009 | 10:15 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: How to remove stripped engine mounting bolts?
There is 2 ways I know of to remove stripped bolts and screws
The way I mainly use is to get a dremel and cut a slit in the bolt and use a flathead to unscrew it. I had to do this on the chassis of a RC car I have to get the engine off after a screw stripped the other day.
Another way I know of at hardware stores they usually sell a screw extracting kit for a drill and you can drill it into the screw and it locks in place and will unscrew the stripped bolt
Last way I know of is to drill it completely out which is NOT recommended as this has the highest chance to cause damage and break the bit
