RE: Which would you rather build on?
Also, no matter what you use for a surface, remember to put wax paper between the parts you are glueing & the surface of your board. If you don't,everything will be glued together. ( My first build I ended up with a wing-half that had 4 ceiling tiles adhered to it.)
