RCU Forums - View Single Post - Jeesh, another balanceing problem
Old 08-22-2009 | 03:24 PM
freeair
Default RE: Jeesh, another balanceing problem
something doesn,t sound right with your balance . 14 ounces of lead weight [ almost a pound ] is heavy, you should remove the lead weights and start with all radio / servos set up closer to the front , check the c.o.g at 1/3 back from the leading edge.
