RCU Forums - View Single Post - Yep, another beginner build question...
Old 08-22-2009 | 06:10 PM
  #61
Alex7403's Avatar
Alex7403
Default RE: Yep, another beginner build question...
Yes you guys got it bad...... guess how i know this.....
Kit building tools
• Building board (must be straight and soft to pin)
• Roll of wax paper
• Metal rulers: 6”, 12”, 36”
• Razor blade saw (the one with the red handle, ZONA is recommended)
• Hobby knife with #11 blades
• Tweezers
• Set of files - round, rectangular
• Sanding block 11” and 80, 150 grit rolls, 400 wet and dry
• Masking tape
• Clamps: small to medium of any shape and form as many as possible, you cannot have too many of them.
• T-pins – the smallest ones and cushion for pins
• Plastic caliper to measure balsa thickness (optional)
• Wing ribs jig (the orange thing)
• Hand drill bits (better then using a power drill!!!)
• Rubber bands
• 12” or 18" quick grips for joining wing halves
• 90* deg triangle
• Long nose pliers
• Standard and metric hex wrenches
• Hobby syringe for aliphatic glue
• Clevis tool
• Epoxy 30 min
• Aliphatic glue-Elmers pro wood glue or Titebond 2
• CA-thin and med
• Epoxy mixing popsicle sticks and mixing cups
• Woodfiller - elmers
• Covering Sealing iron
• Heat gun
• Soldering iron
• Pocket thermometer
• Single edge razor blades
• Slot hinging machine
these are the most important and most used tools.
