ORIGINAL: supertib
The 70 does have alot of torque, but it lacks any real HP or RPM range..... you need alot more then low end torque to hit 50 even will all the gearing in the world...I doubt you seen 50 MPH with that engine, it just doesn't have the HP to push that kind of MPH......The modified Picco 28 makes almost 100% more HP and is barely able to push 50........just Gearing alone doesn't make MPH you really need HP........
ah yes, making facts about things you know nothing about yet again. now, just for the record, and no cheating, tell me just how much "real hp and rpm range" does the .70 have?
im sure youve modded dozens of them and found the italian picco 28's much much better in a number of areas such as port duration, crankshaft materials, and bearing quality.... of course.....
