RCU Forums - View Single Post - JetJoe JJ-1400 Start-Up Problems
Old 08-22-2009 | 11:55 PM
chw757s6640
My Feedback: (59)
Default JetJoe JJ-1400 Start-Up Problems
Help! I bought a JJ-1400 as a side project. I have it setup on a test bench and receive an error when performing the following steps:
1. Fill Tank with Kerosene & 5% Aeroshell 500 Turbine Oil.
2. Fill Starter Gas tank with Powermax.
3. Turn on Transmitter.
4. Turn on Receiver & ECU.
5. Advance Throttle Trim to Full UP.
6. Green light is displayed on ECU.
7. Advance Throttle Stick to Full UP and then Full DOWN to begin start sequence.
8. The fuel pump starts for about seconds. (Fuel line is filled with fuel)
9. GSU handheld shows glow plug test. (Passed)
10. GSU displays the error (BadStart).
Nothing else happens. No action from the starter motor, fuel or gas solenoids.
Any ideas?
FYI - This is the JJ-1400 full auto start with flightworks fuel pump.
ID:	1261171   Click image for larger version
ID:	1261172   Click image for larger version
ID:	1261173   Click image for larger version
ID:	1261174   Click image for larger version
ID:	1261175   Click image for larger version
ID:	1261176   Click image for larger version
ID:	1261177   Click image for larger version
