RCU Forums - View Single Post - Comp ARF Spitfire build
Old 08-23-2009 | 05:03 PM
CaptainFlynn's Avatar
CaptainFlynn
Default RE: Comp ARF Spitfire build
Ailerons. I use double ball link horns for the ailerons as you can see on the picture. I didnt locate any pre-installed support wood in the hollow ailerons, so I decided to add some wood between the control arms.
After some dreme'ling, its time to see how everything fits. As you can see there is a bit of sanding needed to get enough elevator movement with those horns.
ID:	1261722   Click image for larger version
ID:	1261723   Click image for larger version
