RE: CGRCJets A-10 Build Thread
Here are some pics of the rear wing mounting area formers. You will tack everything together but the rear former. Its hard to see in the pic. but the long skinny formers that cradle the rear wing are sitting on top of the former that is used for the bolting of the rear wing. You will be able to tell when you tack this all together because they are notched for one another. Scuff the area up and put your glue on the inside of the rear lip where this former goes and put it in place. You will take and put some glue on the opposing lip and slide the other part of the structure in through the engine nacelle area and put it in place. Tack it with CA to the rear former after you get it in place. You can then proceed with using the former glue and finish gluing it in. You will also want to throw some of this glue in the void between the fuse and the skinny wing cradles on the inside. This will need to be filleted to fill this void in. There will be a slight modification in, incodence to this area but i will need to get some more photos to show you.
chris
