RCU Forums - View Single Post - JetJoe JJ-1400 Start-Up Problems
Old 08-23-2009 | 07:24 PM
Ruizmilton's Avatar
Ruizmilton
My Feedback: (29)
Default RE: JetJoe JJ-1400 Start-Up Problems
Chris:
I think what has everyone confused is that you state that your priming is working fine (you go full throtle for I believe four seconds and the pump will run for one second) leading everyone to think that the pump wiring is correct, but then you state that during the first few seconds after commanding a starting sequence the pump runs, if that is the case and your ECU is set-up and wired correctly then it is defective, please validate that the pump is actually running after you trigger a starting sequence. If you find out that the pump is not really running as you stated before, then you should be OK on the pump, next step is to check the starter power parameters, do you know how to get into the programming menu of the ECU?
Let me know
