RE: CGRCJets A-10 Build Thread
!/4" doublers on inside of engine nacelle former with blind nut for mounting nacelle to fuse. We drilled 4 small holes in the bottom of the fuse, 2 in the back area and 2 in the front area of the nacelle section for these bolts to be accessed. They will go through the fuse former and up into the nacelle former. The same type of holes were used to mount the back part of the wheel nacelle and the rear wing. The rear wing has 2 bolts and a dowel at the leading edge.
chris
