RE: Strange problem with Homie 30cc on gas/glow...
are you using the same plug to run gas and oil mix are are you changing the plug out ? I thing I read some where here on rcu that gas and oil mix will mess up a glow plug i might be wrong on my gas to glow i just run it dry and use trans mission fluid as an after engine run oil michael
