RCU Forums - View Single Post - COX TD .09 HELP
Old 08-23-2009 | 11:37 PM
Remby
Default RE: COX TD .09 HELP
Yes, sounds like a fuel feed issue. The engine will run if you use what is described in the above post, everything I can add was covered well by the others, follow the ideas and it will go.
You will need that set of wrenches sooner or later, for sure.
