RCU Forums - View Single Post - Big Stik 60 Weak Spot
Old 08-24-2009 | 09:30 AM
DenverJayhawk's Avatar
DenverJayhawk
Default RE: Big Stik 60 Weak Spot
where in the peg do you drill a small hole? The peg is formed when you join the two wing halves together with epoxy. If you drill right down the center of the peg, you'll weaken the epoxy used to join the wing halves.
